Введение
This guide will show each detailed step to removing and replacing the battery in the Motorola G7 Play, model number XT1952-3 or XT1952-2. The battery is what keeps the device powered when disconnected from a charger. If the device does not power on or does not hold a charge this can possibly mean that the battery is no longer working. Look out for a swollen or leaking battery. If there is a swollen or leaking battery, be cautious and follow iFixit’s guide on what to do if a battery is swollen.
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
Press the tool into the hole to eject the tray.
Remove SIM Card Tray.
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Next, remove the nine 3.2mm Phillips #00 screws from the motherboard cover with a 00 Phillips bit.
Using an iFixit opener tool, detach the fingerprint sensor and the other 5 cables from the motherboard.
Remove the 0.4mm Phillips #00 screw from the motherboard with a 00 Phillips bit.
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
Remove the cover.
Using the iFixit opening tool, carefully pry up the charging port assembly cover.
Using an iFixit opening tool, detach the cables from the charging port assembly.
7 участников успешно повторили данное руководство.
