Введение
When the Motorola G7 Play, models XT1952-3 and XT1952-2, no longer charges, it could be due to a failing charging port. This replacement guide provides efficient steps to get the device working again. If replacing the charging port doesn’t fix the issue, attempt to replace the battery with this guide.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
Using the iFixit opening tool, carefully pry up the charging port assembly cover.
Using an iFixit opening tool, detach the cables from the charging port assembly.
9 участников успешно повторили данное руководство.
Один комментарий
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
How long do you have to use the heat gun before the glue loosens?
Pamela DeMars - Ответить
It's worked for me with about maybe 15-20 seconds of heating per side.
Matthieu Bister - Ответить
I could not get the pick started under the cover. Ruined several tips. I started with a hair dryer and switched to a heat gun. Be careful with a heat gun! 😬
K Goatee - Ответить
