Введение
This is a fingerprint scanner replacement guide for the Motorola Moto G7 Play, specifically the XT1952-3 and XT1952-2. The fingerprint is an important feature for the device, as it helps provide extra security to keep files safe. If the device no longer unlocks when the sensor is touched, then it should be replaced.
Инструменты
Запчасти
Детали не указаны.
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
Remove the fingerprint scanner from the device.
Еще один человек закончил это руководство.
