Введение
This guide will show each detailed step to removing and replacing the front facing in the Motorola G7 Play, model number XT1952-3 or XT1952-2. The front camera is used to take selfie photos on the phone. If the phone doesn’t have a way to capture selfie photos the front facing camera is no longer working.
Выберете то, что вам нужно
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
Remove the motherboard from the device.
Separate the front facing camera from the motherboard while removing the adhesive .
