Введение
This guide’s easy to follow steps show how to replace the rear camera of the Motorola Moto G7 Plus (model XT1965). The default camera is 16-megapixel, with f1.7 aperture, object image stabilization, and a 2160p video recording at 30 fps camera. This is denoted by the circular glass on the back of the phone.
Before starting the repair, check the list of tools that you will need. To replace the camera, a new compatible camera will also be needed.
Ensure the device is turned off and not connected to any power sources.
Инструменты
Запчасти
Детали не указаны.
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
Once enough adhesive has been removed, you should be able to separate the screen, gently lifting from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver.
Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable.
The screen will be detached from the device.
Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
Use the spudger to carefully slice through the black adhesive.
Use a Torx T5 screwdriver to remove the four 2.7mm screws.
Use the SIM card ejector tool to remove the SIM card tray where circled.
Completely remove the SIM card tray from the phone as shown in the picture.
Use a Torx T5 screwdriver to remove the six 2.7mm screws and one 3.0mm screw.
Remove the plate from the phone.
Gently lift up the piece either with your fingers or a spudger.
Use the reverse tweezers to gently remove the piece from underneath.
