Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If you want to perform advanced repairs on the Motorola Moto G7 Plus (model XT1965), you will likely need to remove the screen first. This guide will show you how to quickly and easily do so. If additionally you want to replace the screen, follow the steps of this guide in reverse using a new screen and adhesive as necessary.
If you are removing a shattered screen, applying force may cause glass shards to pop off. Be gentle and, if necessary, use eye protection.
There are some required tools that are listed below. Ensure the phone is turned off before beginning.
Запчасти
Детали не указаны.
  1. Insert an opening pick under the screen, starting at the top of the phone. Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
    • Insert an opening pick under the screen, starting at the top of the phone.
    • Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to sever this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen, gently lifting from the left side of the phone.
    • While not necessary, applying a heat gun will weaken the adhesive, making this step easier.
  2. Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver. Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
    • Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver.
    • Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Use the pointy end of the spudger to lift the metal casing where circled. The device is rotated 90 degrees Counterclockwise from original orientation.
    • Use the pointy end of the spudger to lift the metal casing where circled.
    • The device is rotated 90 degrees Counterclockwise from original orientation.
  5. Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable. The screen will be detached from the device.
    • Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable.
    • The screen will be detached from the device.
    • The device is rotated 180 degrees from original orientation.
Заключение
3 участников успешно повторили данное руководство.
Xander Wallace
Участник с: 10.02.2020
161 Репутация
1 руководство автора
Команда
Cal Poly, Team S22-G5, Regan Winter 2020 Участник Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 членов
Автор 13 руководств
Комментариев: 2
Althrough a simple fix, one should be weary if the glass is shattered. I just did this, and there were a few spliters left on the adhesive, and of course sticking to it. So if you want to replace your screen due to broken glass, make sure to wear protection and remove the splinters carefully, otherwise you may be tempted to press on the new display to strongly, because you want to stick it to the whole brim.
isoein typ - Ответить
I completed this fix, and it wasn’t too bad. Just watch out when gluing back the screen not to put glue over the microphone hole at the bottom. This would be the phone microphone mouthpiece, you can see a small notch on the bottom of the screen, beside the “motorola” “m” on the front . I put glue there without knowning and the microphone is now very muted.
Richard Gauvreau - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 44
За последние 30 дней: 215
За всё время: 2,008
