Motorola Moto G7 Plus Speaker Replacement
Выберете то, что вам нужно
  1. Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: шаг 1, изображение 1 из 2 Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: шаг 1, изображение 2 из 2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: шаг 2, изображение 1 из 2 Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: шаг 2, изображение 2 из 2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Speaker Replacement: шаг 3, изображение 1 из 2 Motorola Moto G7 Plus Speaker Replacement: шаг 3, изображение 2 из 2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: шаг 4, изображение 1 из 2 Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: шаг 4, изображение 2 из 2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Speaker Replacement, Speaker: шаг 5, изображение 1 из 2 Motorola Moto G7 Plus Speaker Replacement, Speaker: шаг 5, изображение 2 из 2
    • Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
  6. Motorola Moto G7 Plus Speaker Replacement: шаг 6, изображение 1 из 3 Motorola Moto G7 Plus Speaker Replacement: шаг 6, изображение 2 из 3 Motorola Moto G7 Plus Speaker Replacement: шаг 6, изображение 3 из 3
    • Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
    • A medium amount of force may be required.
Заключение
Javier Guerra
Участник с: 02/10/20
300 Репутация
1 руководство автора
Команда
Cal Poly, Team S22-G5, Regan Winter 2020 Участник Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 членов
Автор 17 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 14
За всё время: 2,329
