Введение
The speaker in the Motorola Moto G7 is a basic bottom-ported speaker made by Dolby Audio. The speaker is used to transmit noise out of the phone without any external headphones or Bluetooth speaker used. A broken speaker may consist of poor audio quality or no audio at all with the volume turned on.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning, make sure the device is unplugged from any chargers or headphones. Before starting, grab suggested tools and a new speaker.
Выберете то, что вам нужно
Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
Excessive glass and adhesive around the edges should be removed with the spudger.
Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
Use a spudger to gently take off the metal piece that was held down by the screws.
A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
Remove three 3.7mm T3 Torx screws from the bottom of the phone.
Use the spudger to gently lift the speaker out of the phone.
3 участников успешно повторили данное руководство.
Один комментарий
Could you perhaps offer any advice on how to source one of these bottom-ported speakers?
