Введение
This guide will show you step-by-step how to replace the back casing.
Выберете то, что вам нужно
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
Repeat the 3 steps above for the top, bottom, and opposite side.
