Motorola Moto Q Front Casing Replacement
Выберете то, что вам нужно
  1. Motorola Moto Q Front Casing Replacement, Back Casing: шаг 1, изображение 1 из 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Front Casing Replacement: шаг 2, изображение 1 из 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Front Casing Replacement: шаг 3, изображение 1 из 2 Motorola Moto Q Front Casing Replacement: шаг 3, изображение 2 из 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Front Casing Replacement: шаг 4, изображение 1 из 2 Motorola Moto Q Front Casing Replacement: шаг 4, изображение 2 из 2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Front Casing Replacement, Camera: шаг 5, изображение 1 из 2 Motorola Moto Q Front Casing Replacement, Camera: шаг 5, изображение 2 из 2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Front Casing Replacement: шаг 6, изображение 1 из 2 Motorola Moto Q Front Casing Replacement: шаг 6, изображение 2 из 2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Front Casing Replacement: шаг 7, изображение 1 из 2 Motorola Moto Q Front Casing Replacement: шаг 7, изображение 2 из 2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Front Casing Replacement: шаг 8, изображение 1 из 2 Motorola Moto Q Front Casing Replacement: шаг 8, изображение 2 из 2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q Front Casing Replacement, LCD Display: шаг 9, изображение 1 из 2 Motorola Moto Q Front Casing Replacement, LCD Display: шаг 9, изображение 2 из 2
    • Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
    • Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
    • Note: the orange band is connected to the logic board by a small connector.
  10. Motorola Moto Q Front Casing Replacement: шаг 10, изображение 1 из 3 Motorola Moto Q Front Casing Replacement: шаг 10, изображение 2 из 3 Motorola Moto Q Front Casing Replacement: шаг 10, изображение 3 из 3
    • Wedge the spudger in between the logic board and the front casing and gently lift while pulling away from the orange ribbon.
    • Note: it is easier to remove the logic board by prying upwards near the top of left corner phone.
  11. Motorola Moto Q Front Casing Replacement: шаг 11, изображение 1 из 3 Motorola Moto Q Front Casing Replacement: шаг 11, изображение 2 из 3 Motorola Moto Q Front Casing Replacement: шаг 11, изображение 3 из 3
    • Wedge the plastic opening tool between the LCD screen and the metal casing holding it in and lift gently.
    • Note: the LCD screen is also held in place by a silver tape. Simply pull the screen from one side to other to remove the screen completely.
  12. Motorola Moto Q Front Casing Replacement, Keyboard: шаг 12, изображение 1 из 3 Motorola Moto Q Front Casing Replacement, Keyboard: шаг 12, изображение 2 из 3 Motorola Moto Q Front Casing Replacement, Keyboard: шаг 12, изображение 3 из 3
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
  13. Motorola Moto Q Front Casing Replacement, Front Casing: шаг 13, изображение 1 из 1
    • Remove the navigation buttons by pushing them with your finger(s) until they come loose.
    • Now simply peel the buttons off.
    • The buttons are held in place by glue. it may require a little extra pull to take off the buttons.
Заключение
Еще один человек закончил это руководство.
Luis Herrera
Участник с: 01/21/10
52 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 16-33, Maness Winter 2010 Участник Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 17,220
