Введение
This guide will show you step-by-step how to replace your worn out keyboard buttons.
  1. Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Use the T6 screwdriver to remove the four screws holding the casing together.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Gently lift and remove the back casing. Gently lift and remove the back casing.
    • Gently lift and remove the back casing.
  6. Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards. Gently rotate/wiggle the cover until you can pull it off the phone.
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  7. Using your fingers, remove the plastic piece that holds the camera in place. Using your fingers, remove the plastic piece that holds the camera in place.
    • Using your fingers, remove the plastic piece that holds the camera in place.
  8. Carefully pry up the upper circuit board with the spudger. The second picture shows what your phone should look like when the upper circuit board is removed.
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  9. Take out the camera and attached chip with the iPod removal tool.  Carefully pry the chip off its connection and the camera will come out too. Take out the camera and attached chip with the iPod removal tool.  Carefully pry the chip off its connection and the camera will come out too.
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  10. The keyboard is held in place with a little bit of glue. Simply lift the keyboard buttons with your hands pulling from one side to the other. Simply lift the keyboard buttons with your hands pulling from one side to the other.
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
Заключение
Luis Herrera
Участник с: 21.01.2010
52 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 16-33, Maness Winter 2010 Member of Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 3,987
