Введение
This guide will show you step-by-step how to replace your worn out keyboard buttons.
Выберете то, что вам нужно
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
Repeat the 3 steps above for the top, bottom, and opposite side.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Carefully pry up the upper circuit board with the spudger.
The second picture shows what your phone should look like when the upper circuit board is removed.
Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
Simply lift the keyboard buttons with your hands pulling from one side to the other.
