Выберете то, что вам нужно
Видео обзор
Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
Place the guitar pick into the gap.
Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
19 участников успешно повторили данное руководство.
3 Комментариев
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
What type of adhesive do you use to reseal the back cover?
