Введение
Use this guide to replace the rear-facing camera flash in your Motorola Moto X.
Выберете то, что вам нужно
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Carefully slide the plastic opening tool around the corner, freeing it from clips.
Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Starting from the SIM slot side, carefully peel the back cover off of the phone.
Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
Pull the flash cable straight out of its socket.
Шаг 11 Back Cover
Careful: step 11 is sourced from a guide that's marked as in-progress.
Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive.
Remove the flash assembly from the back cover.
2 участников успешно повторили данное руководство.
Один комментарий
Where did you buy the flash flex replacement?? I cannot find it.
