Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace a broken camera in your Motorola Moto X, its lunch somewhere, and your food ain't gonna Instagram itself.
Выберете то, что вам нужно
Видео обзор
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Carefully slide the plastic opening tool around the corner, freeing it from clips.
Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Starting from the SIM slot side, carefully peel the back cover off of the phone.
Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
Pull the flash cable straight out of its socket.
Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
Use the flat end of a spudger to pry up the lower antenna assembly and free it from the phone.
Remove the antenna assembly.
Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
Use the flat end of a spudger to disconnect the NFC antenna cable connector.
Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector.
Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery.
Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Use the adhesive pull-tab to lift the battery from its recess.
Remove the battery from the phone.
Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
Remove the headphone jack/speaker assembly.
Push the tip of a spudger under the microphone assembly clip to free it from the earpiece speaker.
Use the flat end of a spudger to free the microphone assembly cable connector.
Use tweezers to remove the microphone assembly.
Disconnect the front-facing camera cable connector.
Remove the front-facing camera from its recess with a pair of tweezers.
Insert the flat end of a spudger under the motherboard above the button assembly cable, and pry it out of the phone.
Gently lift the motherboard out of the phone, rotating it from the SIM slot edge of the phone.
Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector.
Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
Use the flat end of a spudger to flip up the retaining tab on the rear-facing camera ZIF cable connector.
Remove the rear-facing camera from the motherboard.
10 участников успешно повторили данное руководство.
4 Комментариев
This took me about an hour or so to do after I got the right tools. I ordered the iOpener "kit" and stupid me thinking that ifixit would directly link you from this page to a kit that works with it, so I didn't read that the kit comes with a T5 torx bit and not a T3. Also no tweezers. Other than that this guide works perfect. The only tricky parts really were getting the battery out; "mild adhesive" my !@#. I used the black tool to slowly pry the battery out. Be patient and the adhesive will give. The other tricky part was getting the motherboard plugged back in. I thought I had it in the first time but apparently didn't. If you get it all back together and all the phone does when you turn it on is do a 1-2sec vibrate every 10 sec or so then check the connection on the motherboard. Great guide for getting your phone DOD ready. Or any job that doesn't allow camera phones on site!
I was successful replacing both my non-functioning camera, a battery getting on the weak side, and a new back cover (went for one of those colorful back covers sold on eBay). The two things that tripped me up were 1) dealing with that sticky gasket between the antenna and the noise-canceling mic (Step 20), and 2) getting the cover glass to stay put on the new back cover. For 2), I ended up fashioning my own adhesive with 2-sided scotch tape.
*ALSO* You really don't need to do Step 35. Leave the motherboard plugged in, and simply remove and re-attach the camera in place.
I went through each step methodically and only had problems removing the top black cover in step #28. The assembly came off with the ear speaker attached to it, nonetheless was able to put it back. Just be wary that it might not be as easy as pictured.
When putting it all back together though I got an unwelcome surprise... somehow instead of getting the phone turning on and loading android, I got the symbol of the battery reading 80% and a large battery outline icon in the middle of the screen against white background with a light blue indicator reflecting visually that 80% charge. Anyone got a similar issue? I couldn't get android to start as it usually would. What gives? (Thanks for any help! :)
First I just want to say thank you for putting together this wonderful guide.
I've replaced the camera and it works but the camera has a problem focusing and all the pictures are blurry. Do you think it's the new camera or a software issue. This is the second camera I got from Phone Parts USA that has done this. Any suggestions or advice would be greatly appreciated!
