Motorola Moto X4 Motherboard Replacement
Выберете то, что вам нужно
  1. Motorola Moto X4 Motherboard Replacement, SIM Card Tray: шаг 1, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, SIM Card Tray: шаг 1, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, SIM Card Tray: шаг 1, изображение 3 из 3
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray, located at the top left edge of the phone.
    • Press to eject the tray.
    • Remove the tray from the phone.
  2. Motorola Moto X4 Motherboard Replacement, Heat the screen: шаг 2, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement, Heat the screen: шаг 2, изображение 2 из 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
    Complete novice. Getting old screen off was time consuming! I was too afraid of ruining something by overheating. Spent many hours trying to use iopener, afraid to risk bursting it in microwave. Read many comments in the iopener use guide; a guy said to get the screen temp up to 120-130F. Saw several youtube videos esp. Witrig one on replacing Moto x4 screen, they used heat gun 100C=212F so I got braver and put my phone on kitchen hot plate. Measured temperature by laying stem of candy thermometer on the surface. When hot plate got to 150-160F I finally got a pick under phone ‘s glass edge & got the screen off. Hot plate temp. not stable, guess phone was there a few minutes. May have damaged display but was replacing it anyway. Now new screen installed everything working properly! I’m not sure I was using the suction cup when I finally was able to push the pick under the edge.
    Nahariyah Mosenkis - Ответить
  3. Motorola Moto X4 Motherboard Replacement, Create a gap: шаг 3, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Create a gap: шаг 3, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Create a gap: шаг 3, изображение 3 из 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    On the left side it is a very thin strip of adhesive—but there are other places where there is alot more adhesive—If you look at the black part of the new adhesive-if you have the phone specific adhesive thing—you will get an idea what you might be trying to push through at any given spot on the phone. orient the new one over the old screen to line up holes etc-to understand where the adhesive is.
  4. Motorola Moto X4 Motherboard Replacement, Slice the screen adhesive: шаг 4, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Slice the screen adhesive: шаг 4, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Slice the screen adhesive: шаг 4, изображение 3 из 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  5. Motorola Moto X4 Motherboard Replacement: шаг 5, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 5, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 5, изображение 3 из 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  6. Motorola Moto X4 Motherboard Replacement: шаг 6, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 6, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 6, изображение 3 из 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  7. Motorola Moto X4 Motherboard Replacement: шаг 7, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 7, изображение 2 из 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  8. Motorola Moto X4 Motherboard Replacement: шаг 8, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  9. Motorola Moto X4 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  10. Motorola Moto X4 Motherboard Replacement, Detach the fingerprint sensor cable: шаг 10, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement, Detach the fingerprint sensor cable: шаг 10, изображение 2 из 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  11. Motorola Moto X4 Motherboard Replacement, Disconnect the fingerprint sensor: шаг 11, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Disconnect the fingerprint sensor: шаг 11, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Disconnect the fingerprint sensor: шаг 11, изображение 3 из 3
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  12. Motorola Moto X4 Motherboard Replacement, Disconnect the display cable: шаг 12, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Disconnect the display cable: шаг 12, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Disconnect the display cable: шаг 12, изображение 3 из 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  13. Motorola Moto X4 Motherboard Replacement, Remove the screen: шаг 13, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement, Remove the screen: шаг 13, изображение 2 из 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
    I found that the subsequent steps will be smoother if you spend a little time at this point cleaning out the old adhesive pieces. The picture above shows pulling off some of the old glue strips, but the bullet points don’t mention it. Removing the mid-frame and other steps is easier if the old adhesive has been cleaned out.
    Gordon Bolt - Ответить
    Good point Gordon! I’ve adjusted the wording on the second bullet to point people in the right direction.
    Arthur Shi -
    I’d already used the free form adhesives to glue the screen back on before I realized the kit came with a ready-to-go adhesive sheet. It’d be nice if this were mentioned (or pictured) here.
    Paul Ferrell - Ответить
    The provided replacement screen does not have the black plastic film w/ 5 x 3 holes in it
    photo to illustrate: top is replacement screen. Bottom is old screen, w/ black film w/ holes
    Not sure how to proceed here.
    Etienne Grossmann - Ответить
  14. Motorola Moto X4 Motherboard Replacement, Unscrew the midframe: шаг 14, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement, Unscrew the midframe: шаг 14, изображение 2 из 2
    • Remove the following twenty screws securing the midframe:
    • Eleven silver 2.7 mm-long T3 screws
    • Nine black 3.6 mm-long T4 screws
    • The midframe is still held in place by clips.
    For some reason, my brand new T4 screwdriver didn’t fit the 9 designated T4 screws very well—it seemed a little large. So I carefully tried the T3 screwdriver and it worked perfectly! Not sure if the head has changed sizes on those longer screws in some assemblies….
    Kenneth Lassman - Ответить
    Hi Kenneth! I’m glad the T3 worked! There have been many instances with Moto phones where the screw tolerances are quite variable—they normally shows up in the T3-T4 range.
    Arthur Shi -
  15. Motorola Moto X4 Motherboard Replacement, Loosen the midframe: шаг 15, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Loosen the midframe: шаг 15, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Loosen the midframe: шаг 15, изображение 3 из 3
    • The next few steps show how to loosen the midframe clips.
    • Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
    • Insert an opening pick in the edge to hold the midframe in place.
  16. Motorola Moto X4 Motherboard Replacement: шаг 16, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 16, изображение 2 из 2
    • Insert the flat end of a spudger under the lower right edge of the midframe and pry up to release the midframe clip.
  17. Motorola Moto X4 Motherboard Replacement: шаг 17, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 17, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 17, изображение 3 из 3
    • Grasp the lower edge of the midframe and pull the edge slightly to the right, to clear the metal midframe clip.
  18. Motorola Moto X4 Motherboard Replacement: шаг 18, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 18, изображение 2 из 2
    • Insert the point of an opening pick under the top left corner of the midframe and twist slightly to release the top clip.
  19. Motorola Moto X4 Motherboard Replacement, Remove the midframe: шаг 19, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement, Remove the midframe: шаг 19, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement, Remove the midframe: шаг 19, изображение 3 из 3
    • Remove the midframe.
    • To reinstall the midframe:
    • Align the the midframe's top edge to the phone and press it into position.
    • Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
    • Press the midframe's bottom edge into position.
  20. Motorola Moto X4 Motherboard Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Insert the point of a spudger underneath the top edge of the battery connector.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently pry up the connector to disconnect the battery.
  21. Motorola Moto X4 Motherboard Replacement: шаг 21, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 21, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 21, изображение 3 из 3
    • To re-connect the battery, align the connector on top of the socket, and press it down with your finger or a spudger.
    After disconnecting the battery, there is 1x T3 (near the camera) and 2xT4 screws (near the headphone jack and usb port) that had to be removed, then the camera clips flipped up, then that board carefully removed (after ejecting the sim/memory cards) before being able to get to the two screws for the camera module.
    For reassembly, the camera cables had to be carefully held back while the board was repositioned.
    Steve Welander - Ответить
    Hi Steve,
    Thanks for the feedback! What you are describing sounds like the steps found in this guide. Can you see if anything is missing there? Thanks!
    Arthur Shi -
    Hi Arthur, I am doing this repair right now, and yes, this guide should have steps 21-25 from the linked guide inserted after step 20. Getting to the Rear Camera requires removing the motherboard, and indeed you can see in the pictures in what is currently Step 21 of this guide that the motherboard is removed (note the missing large silver rectangle in the upper-left, which is the SIM card tray, for instance, or any electronics in the upper-right)
    Joel Bradshaw - Ответить
    Although notably, the vibrating motor doesn’t have to be unplugged from the socket, just removed from the case along with the motherboard. I advise that, as the motor’s connection is very small and fragile.
  22. Motorola Moto X4 Motherboard Replacement, Motherboard: шаг 22, изображение 1 из 1
    • Remove the T3 screw that is holding in the motherboard.
  23. Motorola Moto X4 Motherboard Replacement: шаг 23, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 23, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 23, изображение 3 из 3
    • Use flat edge of the spudger to pry up the two blue connectors near the top of the device.
  24. Motorola Moto X4 Motherboard Replacement: шаг 24, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 24, изображение 2 из 2
    • Use flat side of spudger to pry up connector near the bottom of the device.
  25. Motorola Moto X4 Motherboard Replacement: шаг 25, изображение 1 из 3 Motorola Moto X4 Motherboard Replacement: шаг 25, изображение 2 из 3 Motorola Moto X4 Motherboard Replacement: шаг 25, изображение 3 из 3
    • Using a pair of tweezers disconnect the vibrating motors connector near the bottom of the device.
    • Caution: these wires are very delicate!
    • Also note that while it may not look the same, this connector also lifts up, similar to the camera and battery connectors, and does not slide out.
    • Alternatively, you can also leave the connector plugged in and simply remove the vibration motor from the frame and keep it together with the motherboard as you remove it, being careful to not dangle it from the small wires.
  26. Motorola Moto X4 Motherboard Replacement: шаг 26, изображение 1 из 2 Motorola Moto X4 Motherboard Replacement: шаг 26, изображение 2 из 2
    • Carefully pry up the motherboard using the spudger.
    • The previously disconnected wires may have to be held back in order to easily remove the motherboard.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
7 участников успешно повторили данное руководство.
Nick Wolfe
Участник с: 01/24/18
709 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S18-G4, Livingston Winter 2018 Участник Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 членов
Автор 13 руководств
8 Комментариев
sir mere ko board chahiye
abdul - Ответить
I have Moto x4 mother board
Can you call me 833100taa1
anand malladi -
condect no moto x4 ka board chahiye
abdul - Ответить
I am from Hyderabad i need moto X4 mother board
jagadishllb - Ответить
Anana malladi r y working at
ASSALAM O ALKEUM
i need moto x4 board please fair price tell me urgent
i am from karachi pakistan
and my repair my phone
Faisal - Ответить
Asslam o alekum my moto x4 board dead please my moto x4 board change
Faisal - Ответить
Moto x4 power key replacement details
Fun Clips - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 27
За всё время: 8,233
