Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to remove and replace a dead or low battery in a Motorola Moto Z2 Play. If your battery is swollen, take appropriate precautions.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
  1. Power off your phone before you complete any replacement steps.
    • Power off your phone before you complete any replacement steps.
  2. Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Place suction cup in the middle of the screen and press down.
    • Place suction cup in the middle of the screen and press down.
  4. Pry the screen by wedging the plastic opening tool under the screen at the charging port. Work your way around the screen with the plastic opening tool. When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Use a suction cup to lift up screen from left to right. If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly. Failure to lift screen from left to right can cause damage to interior wires of your phone.
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  7. Identify ribbon connector at the top right of the phone. Pry the black locking bar up gently with a plastic opening tool. Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  8. Identify the ribbon cable, located at the bottom right of the phone. Disconnect the ribbon cable, located at the bottom right of the phone, by pulling out and back with tweezers. Excessive force is not needed.
    • Identify the ribbon cable, located at the bottom right of the phone.
    • Disconnect the ribbon cable, located at the bottom right of the phone, by pulling out and back with tweezers.
    • Excessive force is not needed.
  9. Lift the screen from the phone to completely detach.
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  10. Remove the orange tape, located at the bottom right of the phone, using tweezers. Do not discard tape.
    • Remove the orange tape, located at the bottom right of the phone, using tweezers.
    • Do not discard tape.
  11. Detach the red and black battery wire by lifting up with tweezers. Detach the red and black battery wire by lifting up with tweezers.
    • Detach the red and black battery wire by lifting up with tweezers.
  12. Peel back the black tape that is located on the battery. Make sure you pull back gently so you can reuse the tape with reassembly.
    • Peel back the black tape that is located on the battery.
    • Make sure you pull back gently so you can reuse the tape with reassembly.
  13. Lift  the black tape and slide a card under the battery. Align the card parallel and under the battery. Wedge the card further under the battery.
    • Lift the black tape and slide a card under the battery.
    • Align the card parallel and under the battery.
    • Wedge the card further under the battery.
    • Lift the card up to assist in removing the battery from the adhesive.
  14. Lift to remove the battery from the device completely.
    • Lift to remove the battery from the device completely.
Заключение
After completing this guide, calibrate your newly-installed battery.
22 участников успешно повторили данное руководство.
mitch miller
Участник с: 24.01.2018
1 714 Репутация
Автор 8 руководств
Команда
Cal Poly, Team S19-G5, Livingston Winter 2018 Участник Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 членов
Автор 18 руководств
Комментариев: 9
Awesome guide! where can someone get a replacement battery in Canada?
xbddd777 - Ответить
Great instructions, clear and concise.
thank you
David Wyatt - Ответить
so now that I've heated the adhesive to get the screen off do I need to apply new adhesive? or simply reheat it?
eli Factotum - Ответить
Hi Eli,
The most ideal option would be to replace the adhesive. This ensures the best chance for your phone to stay sealed. You can re-use the existing adhesive and it may work well enough for awhile.
Arthur Shi -
What type/brand adhesive do you recommend for this screen instead of trying to reuse the old adhesive. Typical 3M strips?
Jason - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 209
За последние 30 дней: 839
За всё время: 18,890
