Введение
Use this guide to remove and replace a dead or low battery in a Motorola Moto Z2 Play. If your battery is swollen, take appropriate precautions.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you intend to re-use the display, take serious care when heating and inserting tools to separate the display from the rest of the device.
Выберете то, что вам нужно
Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
Pry the screen by wedging the plastic opening tool under the screen at the charging port.
Work your way around the screen with the plastic opening tool.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Use a suction cup to lift up screen from left to right.
Identify ribbon connector at the top right of the phone.
Pry the black locking bar up gently with a plastic opening tool.
Remove the ribbon wires by pulling them out of the connector with a tweezer.
Identify the ribbon cable, located at the bottom right of the phone.
If present, remove kapton (orange) tape covering the cable connector.
Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
Remove the orange tape, located at the bottom right of the phone, using tweezers.
Lift the black tape and slide a card under the battery.
Align the card parallel and under the battery.
Wedge the card further under the battery.
Lift the card up to assist in removing the battery from the adhesive.
After completing this guide, calibrate your newly-installed battery.
37 участников успешно повторили данное руководство.
11 Комментариев
Great instructions, clear and concise.
thank you
so now that I've heated the adhesive to get the screen off do I need to apply new adhesive? or simply reheat it?
Hi Eli,
The most ideal option would be to replace the adhesive. This ensures the best chance for your phone to stay sealed. You can re-use the existing adhesive and it may work well enough for awhile.
