Введение
The antenna is a vital piece of hardware in the i880. It is used to send and receive data submitted between this phone and other devices.
Выберете то, что вам нужно
Remove back cover of the phone by disengaging the clip and lifting up on the cover.
Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
Slide and secure new antenna into position. Make sure metal receiver is facing forward.
