Введение
If you are unable to hear from the speaker, then the speaker may be faulty. This is a guide on how to replace the speaker.
Запчасти
Никакие детали не требуются.
  1. Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
    • Remove all five screw covers with tweezers located in the picture.
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
    • Locate the speaker on the back of the midframe.
    • The speaker is attached to the midframe with adhesive. Remove carefully.
    • Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • Remove the speaker from the midframe.
Заключение
Elizabeth Lee
Участник с: 07.10.2014
92 Репутация
1 Guide authored
Команда
USF Tampa, Team 8-6, Leahy Fall 2014 Member of USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 1
За всё время: 304
