Motorola Q700 Sidekick Motherboard Replacement
Выберете то, что вам нужно
  1. Motorola Q700 Sidekick Motherboard Replacement, Phone: шаг 1, изображение 1 из 1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Motherboard Replacement: шаг 2, изображение 1 из 1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Motherboard Replacement: шаг 3, изображение 1 из 1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Motherboard Replacement: шаг 4, изображение 1 из 1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Motherboard Replacement: шаг 5, изображение 1 из 1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Motherboard Replacement: шаг 6, изображение 1 из 1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Motherboard Replacement: шаг 7, изображение 1 из 1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • Complete steps for removing battery and front cover in order before continuing on to motherboard
  9. Motorola Q700 Sidekick Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove all technical componets
Заключение
Rich
Участник с: 04/08/13
125 Репутация
Автор 6 руководств
Команда
SUNY Cortland, Team 1-4, Getto Spring 2013 Участник SUNY Cortland, Team 1-4, Getto Spring 2013
SUNYCORT-GETTO-S13S1G4
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 13
За всё время: 269
