Введение
Use this repair guide to replace the back housing in a Motorola RAZR2 v9m.
Выберете то, что вам нужно
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Gently press the pointy end of the spudger into the edge of the bumper until it bows and separates from the phone.
Grab the bowed portion of bumper. Gently lift and peel the bumper away from the phone.
Remove the two 4-mm T5 Torx screws, previously hidden beneath the flip stop bumper pad.
Wedge the spudger about 4 mm into the gap between the phone casing and the rear housing.
Pry the rear housing away from the phone until enough is exposed to grasp with your fingers.
Tilt the loosened half of the rear housing away from the phone. The housing should easily separate after tilting it about 45 degrees away from the phone.
2 участников успешно повторили данное руководство.
