Motorola Razr V3 Antenna Replacement
Выберете то, что вам нужно
  1. Motorola Razr V3 Antenna Replacement, Battery: шаг 1, изображение 1 из 2 Motorola Razr V3 Antenna Replacement, Battery: шаг 1, изображение 2 из 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Antenna Replacement: шаг 2, изображение 1 из 2 Motorola Razr V3 Antenna Replacement: шаг 2, изображение 2 из 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Antenna Replacement, Antenna: шаг 3, изображение 1 из 1
    • Unscrew the two 5mm T6 Torx screws form the phone.
  4. Motorola Razr V3 Antenna Replacement: шаг 4, изображение 1 из 1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  5. Motorola Razr V3 Antenna Replacement: шаг 5, изображение 1 из 1
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  6. Motorola Razr V3 Antenna Replacement: шаг 6, изображение 1 из 1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
Заключение
Еще один человек закончил это руководство.
Ross Byers
Участник с: 04/18/13
243 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-46, Amido Spring 2013 Участник Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 членов
Автор 8 руководств
Один комментарий
Elok tenan Jan sing posting
Haryanto - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 3,706
