Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the battery by pushing down on the top and pulling it away from the phone.
Use tweezers to pry off the four rubber screw covers from the inside face.
Remove the four T5 Torx screws that were underneath the rubber covers.
Use the plastic opening tool to pry the top cover away from the phone.
Use the spudger to pry off the plastic lens that covers the LCD screen.
Use the tweezers to gently pry the silver ribbon cable up towards you.
Use he tweezers to flip up the tab.
With the tab up, gently pull the copper ribbon cable out.
Use the tweezers to gently fold the buttons away from the phone.
Use the spudger the speaker from the phone.
Place your thumb on the screen and gently push into the phone.
6 участников успешно повторили данное руководство.
