Введение
This guide will show you how to install the upper casing of the phone. This guide is necessary in order to remove the LCD screen or the call speaker.
Запчасти
Никакие детали не требуются.
  1. Remove the back cover by pressing down the silver button.
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Remove the battery by pushing down on the top and pulling it away from the phone, similar to the cover.
    • Remove the battery by pushing down on the top and pulling it away from the phone, similar to the cover.
    • Use tweezers to pry off all four rubber screw covers from the inside face, pulling them towards you.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
    • Remove the four T5 Torx screws that were underneath the rubber covers.
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
Заключение
Ian Cottengim
Участник с: 18.04.2013
82 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-46, Amido Spring 2013 Member of Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 18
За всё время: 2,143
