Введение
This guide will show you how to remove the motherboard on a Motorola V3c.
Выберете то, что вам нужно
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Use the plastic opening tool to pop the bottom and the sides off the back casing.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull out the two black rubber covers using tweezers.
Pull out the motherboard.
You may also now replace the bottom lower casing
6 человек успешно провели ремонт по этому руководству.
