Выберете то, что вам нужно
Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
Carefully use a metal spudger to pry back panel open.
Carefully open out the back panel to the side of the phone corresponding with the hinge.
Using a plastic opening tool, push the four metal tabs along the edge of the phone in towards the keypad.
Using the plastic opening tool, pry the edges of the keypad until it is loose. Then, pull it off.
Еще один человек закончил это руководство.
