Выберете то, что вам нужно
Press down on the silver battery cover latch located at the top of the phone.
Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
Turn the phone over so that the back of the phone is facing towards you.
Press down on the battery cover latch located at the top of the phone.
Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
Use the plastic opening tool to loosen the cover latch.
Once the cover latch has been loosened, gently pull the cover latch off of the device.
Use a screwdriver with a T6 Torx screwdriver head to turn the screw counter-clockwise (left).
Using the grooves around the edge of the phone, gently pull the front panel away from the phone until it is fully removed from the device.
