Motorola SURFboard SB5101 Standby Key Replacement
Выберете то, что вам нужно
  1. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: шаг 1, изображение 1 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: шаг 1, изображение 2 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: шаг 1, изображение 3 из 3
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: шаг 2, изображение 1 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: шаг 2, изображение 2 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: шаг 2, изображение 3 из 3
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: шаг 3, изображение 1 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: шаг 3, изображение 2 из 3 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: шаг 3, изображение 3 из 3
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: шаг 4, изображение 1 из 2 Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: шаг 4, изображение 2 из 2
    • Position the small black standby in the opening at the top of the case such that the wider teeth of the key is facing up.
    • Gently lower the key so the narrow teeth of the key are resting on the notch (circled in red) just below the opening at the top of the case.
    • If you plan to continue working on the device, check that this key is in place before finally closing the device.
Заключение
Your standby key has been successfully realigned.
2 участников успешно повторили данное руководство.
Bhavik Patel
Участник с: 10/13/14
276 Репутация
Автор 2 руководств
Команда
Clemson, Team 1-2, Benson Fall 2014 Участник Clemson, Team 1-2, Benson Fall 2014
CLEM-BENSON-F14S1G2
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 981
