Введение
Use this guide to replace the keypad.
  1. Push down on the black tab located at the top center of the Motorola phone
    • Push down on the black tab located at the top center of the Motorola phone
  2. Remove the battery by pulling the battery from the top center
    • Remove the battery by pulling the battery from the top center
    • Remove the four (4) T6 Torx screws from the rear metal plate.
    • Insert the flat end of a spudger and pry the metal cover up off the phone
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
    • Remove the 2 newly exposed T6 screws
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Заключение
Jorge Trujillo
Участник с: 19.05.2011
499 Репутация
Автор 4 руководств
Команда
CSU Los Angeles, Team 1-1, Nelson Spring 2011 Member of CSU Los Angeles, Team 1-1, Nelson Spring 2011
CSULA-NELSON-S11S1G1
2 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 9
За всё время: 5,310
