Введение
The battery terminals are the contacts between the battery and the radio and guide the electricity from the battery to the radio. Without properly functioning battery terminals, power cannot be supplied to the radio. Follow the steps below to properly replace the battery terminals.
Выберете то, что вам нужно
Remove the back battery cover by pressing the tab to the left, and lifting.
Remove the batteries currently in the radio.
The orientation of the batteries is specified in the battery compartment.
Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
Now the circuit board can be removed from the back faceplate.
To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
Once the circuit board is removed from the back plate of the radio, the battery terminals can be removed.
From the front side of the two-way radio, use the flathead screwdriver to pry the longer battery terminals up and out of the radio.
To remove the smaller batter terminals, you'll need to turn the radio back over to the back side.
Use the flathead screwdriver to push on the terminal.
Once the terminal is loose, you can turn the radio over and remove it with your hand.
Once the faulty leads are removed, you can insert the new leads. To reassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Gostaria de saber se eu tenho como encontrar a placa para fazer a troca, tenho um rádio da Motorola t400
mauropessoa - Ответить
