Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the back battery cover by pressing the tab to the left, and lifting.
Remove the batteries currently in the radio.
The orientation of the batteries is specified in the battery compartment.
Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
Remove the four 3 millimeter T8 Torx screws from the back of the radio.
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
Gently pull the circuit board away from the front faceplate.
The button contacts can be seen in the red box of the picture.
Dip q-tip in rubbing isopropyl alcohol, and swab button contacts to clean.
Note: Rubbing alcohol will evaporate, and does not need to be wiped off of contacts.
Еще один человек закончил это руководство.
