Введение
Replacing the screen and connector ribbon.
Выберете то, что вам нужно
Gently tug on the upper edge of the faceplate, and it will easily detach.
Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
Remove the SIM card located on the back of the phone.
Unclip the pronged rectangle connector ribbon attached to the motherboard.
Remove the motherboard by lifting it up out of the keypad.
Power off the Motorola V180.
Flip the phone over to its back side.
Hold down the button and slide off the back cover.
Remove the battery.
Remove the motherboard.
Now that the ribbon is loose, the screen (white part) can swing away.
Some of the black "tape" can be peeled back, but the screen is still attached. More work may be required to fully separate this part.
Slide out the part of the connector ribbon that was just attached to the motherboard through this narrow slot in the phone.
The entire connector ribbon unit can now be removed from the phone.
