Запчасти
Никакие детали не требуются.
  1. Press and hold the button on the battery cover Pull the battery cover down and out to remove it Pull the battery cover down and out to remove it
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Remove the batteries by pulling them away from the phone Remove the batteries by pulling them away from the phone
    • Remove the batteries by pulling them away from the phone
  3. Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Use your fingers or a spudger to remove the back cover Use your fingers or a spudger to remove the back cover
    • Use your fingers or a spudger to remove the back cover
  6. Lift and remove buttons by hand Lift and remove buttons by hand
    • Lift and remove buttons by hand
  7. Place your plastic opening tool in between the motherboard and the front cover of the phone Apply a small force to lift the motherboard away from the front cover
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  8. Grip the top of the rubber keypad with your thumb and index finger While holding the keypad start to peel it back from the front cover until the keypad is completely detached While holding the keypad start to peel it back from the front cover until the keypad is completely detached
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  9. Use the spudger to lift the speaker off the front cover Use the spudger to lift the speaker off the front cover
    • Use the spudger to lift the speaker off the front cover
  10. Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
Заключение
Connor
Участник с: 13.01.2015
201 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-6, Sullivan Winter 2015 Member of USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 членов
Автор 16 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 55
