Motorola V276 Headphone Jack Replacement
Выберете то, что вам нужно
  1. Motorola V276 Headphone Jack Replacement, Battery: шаг 1, изображение 1 из 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Headphone Jack Replacement: шаг 2, изображение 1 из 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Headphone Jack Replacement: шаг 3, изображение 1 из 2 Motorola V276 Headphone Jack Replacement: шаг 3, изображение 2 из 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Headphone Jack Replacement, Headphone Jack: шаг 4, изображение 1 из 1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Headphone Jack Replacement: шаг 5, изображение 1 из 1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Headphone Jack Replacement: шаг 6, изображение 1 из 3 Motorola V276 Headphone Jack Replacement: шаг 6, изображение 2 из 3 Motorola V276 Headphone Jack Replacement: шаг 6, изображение 3 из 3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Headphone Jack Replacement: шаг 7, изображение 1 из 1
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Заключение
Jason Kilroy
Участник с: 04/11/10
1 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 27-96, Amido Spring 2010 Участник Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 864
