Введение
If your V325 is having problems charging or holding a charge, you may need a new battery. To remove the battery, please follow the instructions below.
  1. Flip the phone over so that the back is visible.
    • Flip the phone over so that the back is visible.
    • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
  2. While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery. This will only take a moment to do. This will only take a moment to do.
    • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
    • This will only take a moment to do.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side. Remove the battery completely by lifting it straight out of the phone. Remove the battery completely by lifting it straight out of the phone.
    • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
    • Remove the battery completely by lifting it straight out of the phone.
  5. When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
    • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
Заключение
Adrian Doan
Участник с: 19.01.2010
22 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-15, Forte Winter 2010 Member of Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 2,481
