Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisites: Battery, Faceplate
Выберете то, что вам нужно
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Grab the lower edge of the battery at the two bottom corners.
Pull upward on the edges to remove the battery.
Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
With the edges separated, close the phone and lift off the faceplate with your fingers.
Gently peel off the plastic film from the metal plate above the camera lens as shown.
Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
Lift and peel back the tape attaching metal casing to body of the phone.
Gently lift the metal cover and remove to expose the circuit board.
Using a plastic opening tool, pry or lift open the pink door shown.
After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
2 участников успешно повторили данное руководство.
