Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide section shows how to remove the headphone jack from a Motorola V557 phone.
Запчасти
Детали не указаны.
  1. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
    • Push down on the silver button while sliding the back plate down to reveal the battery.
  2. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
    • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  3. Move the the metal slider towards the top of the phone until it clicks out of its original position. Slide out and remove the SIM card. Slide out and remove the SIM card.
    • Move the the metal slider towards the top of the phone until it clicks out of its original position.
    • Slide out and remove the SIM card.
  4. Grip the antenna and twist it counterclockwise to loosen it. When it has been loosened all the way, pull gently to remove the antenna piece.
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
    • Remove the screw covers over the two top screws by prying gently with a pin.
    • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  6. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
    • Remove all four 6.0 mm Torx screws.
  7. Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
    • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
    • Separate and detach the rear casing.
  8. Lift out the headphone jack section from the sides using a push pin. Lift out the headphone jack section from the sides using a push pin. Lift out the headphone jack section from the sides using a push pin.
    • Lift out the headphone jack section from the sides using a push pin.
Заключение
Alex Georges
Участник с: 02.10.2010
40 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 7-50, Amido Fall 2010 Участник Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 членов
Автор 24 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,576
