Введение
How to replace the logic board.
Инструменты
Запчасти
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
NOTE: Make sure screws return to correct place when reassembling.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board to remove.
Почти готово!
Заключение
