Введение
How to replace the motherboard of your Motorola V60c phone.
Выберете то, что вам нужно
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
NOTE: Make sure screws return to correct place when reassembling.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board to remove.
Заключение
