Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This is a guide showing how to replace the Motorola V60 speakers.
Выберете то, что вам нужно
Push in release lever towards top of phone, then use blue spudger to pry case off.
After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
Set cover aside in a safe location.
Carefully grab battery towards bottom of phone.
Lift from bottom and take out of phone, set aside in a safe location.
Unscrew four corner screws with T6 screwdriver.
Note: Top screws are silver and short while bottom screws are black and longer.
Pry off back chassis by wedging spudger in crevice between back panel and phone and lifting.
Insert spudger between speaker and back chassis and lifting.
Note: This may take some effort.
