Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Turn off the phone.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Insert the new battery.
    • Insert the new battery.
  3. Four 5 mm screws are visible (circled in red).
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Gently twist the antenna in a counter-clockwise direction to unscrew it.
    • Gently twist the antenna in a counter-clockwise direction to unscrew it.
  6. Pull the antenna out through the hole in the top of the frame and set it aside. Pull the antenna out through the hole in the top of the frame and set it aside.
    • Pull the antenna out through the hole in the top of the frame and set it aside.
  7. Using a plastic opening tool, lift and remove the antenna casing. Using a plastic opening tool, lift and remove the antenna casing. Using a plastic opening tool, lift and remove the antenna casing.
    • Using a plastic opening tool, lift and remove the antenna casing.
Заключение
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
Участник с: 26.03.2014
501 Репутация
Автор 5 руководств
Команда
Clemson, Team 6-3, Benson Spring 2014 Участник Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 135
