Выберете то, что вам нужно
Insert thumb in the gap between the button and the battery and pry the battery upwards.
Pull the battery out of the phone.
Four 5 mm screws are visible (circled in red).
Using the T6 tool, remove all four 5mm screws and set them aside.
Insert the plastic opening tool between the front and back panels of the lower half of the device.
Slide the tool around the entire frame of the device until it has loosened.
Remove the back of the device.
Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
Remove circuit board.
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
