Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Turn off the phone.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  3. Insert the new battery.
    • Insert the new battery.
  4. Four 5 mm screws are visible (circled in red).
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  5. Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  6. Use the pry bar to carefully remove the headphone jack. Use the pry bar to carefully remove the headphone jack.
    • Use the pry bar to carefully remove the headphone jack.
Заключение
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
Участник с: 26.03.2014
401 Репутация
Автор 4 руководств
Команда
Clemson, Team 6-3, Benson Spring 2014 Участник Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 75
