Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn off the phone.
Turn the device over.
Remove the battery cover.
Insert thumb in the gap between the button and the battery and pry the battery upwards.
Pull the battery out of the phone.
Four 5 mm screws are visible (circled in red).
Using the T6 tool, remove all four 5mm screws and set them aside.
Insert the plastic opening tool between the front and back panels of the lower half of the device.
Slide the tool around the entire frame of the device until it has loosened.
Remove the back of the device.
