Выберете то, что вам нужно
Insert thumb in the gap between the button and the battery and pry the battery upwards.
Pull the battery out of the phone.
Four 5 mm screws are visible (circled in red).
Using the T6 tool, remove all four 5mm screws and set them aside.
Insert the plastic opening tool between the front and back panels of the lower half of the device.
Slide the tool around the entire frame of the device until it has loosened.
Remove the back of the device.
Using back of the plastic opening tool, push the speaker out of the casing.
Remove existing speaker.
Replace with new speaker
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
