Введение
This will show you how to replace your camera.
Выберете то, что вам нужно
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
If the casing has not popped off of the body, remove it carefully from the the phone.
After completing Steps 3-6 in the casing repair guide, your phone should look like this.
Use the spudger to unhinge the four clips around the metal casing of the top logic board.
Gently take off the metal casing of the logic board.
Take your spudger and place it just under the camera as shown.
With a small force, the camera should remove easily.
Еще один человек закончил это руководство.
