Motorola W490 Flex Cable Replacement
Выберете то, что вам нужно
  1. Motorola W490 Flex Cable Replacement, Phone Casing: шаг 1, изображение 1 из 2 Motorola W490 Flex Cable Replacement, Phone Casing: шаг 1, изображение 2 из 2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 Flex Cable Replacement, Battery: шаг 2, изображение 1 из 2 Motorola W490 Flex Cable Replacement, Battery: шаг 2, изображение 2 из 2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 Flex Cable Replacement, Lower Metal Frame: шаг 3, изображение 1 из 2 Motorola W490 Flex Cable Replacement, Lower Metal Frame: шаг 3, изображение 2 из 2
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  4. Motorola W490 Flex Cable Replacement: шаг 4, изображение 1 из 3 Motorola W490 Flex Cable Replacement: шаг 4, изображение 2 из 3 Motorola W490 Flex Cable Replacement: шаг 4, изображение 3 из 3
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  5. Motorola W490 Flex Cable Replacement: шаг 5, изображение 1 из 2 Motorola W490 Flex Cable Replacement: шаг 5, изображение 2 из 2
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  6. Motorola W490 Flex Cable Replacement: шаг 6, изображение 1 из 3 Motorola W490 Flex Cable Replacement: шаг 6, изображение 2 из 3 Motorola W490 Flex Cable Replacement: шаг 6, изображение 3 из 3
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
  7. Motorola W490 Flex Cable Replacement, Circuit Board: шаг 7, изображение 1 из 3 Motorola W490 Flex Cable Replacement, Circuit Board: шаг 7, изображение 2 из 3 Motorola W490 Flex Cable Replacement, Circuit Board: шаг 7, изображение 3 из 3
    • Identify the flex cable attachment. Indicated in a red square.
    • Detach the bottom half of the flex cable, pop it off of the circuit board.
    • Pick up the loosened circuit board from the phone and set aside.
  8. Motorola W490 Flex Cable Replacement, Upper Metal Frame: шаг 8, изображение 1 из 2 Motorola W490 Flex Cable Replacement, Upper Metal Frame: шаг 8, изображение 2 из 2
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  9. Motorola W490 Flex Cable Replacement: шаг 9, изображение 1 из 3 Motorola W490 Flex Cable Replacement: шаг 9, изображение 2 из 3 Motorola W490 Flex Cable Replacement: шаг 9, изображение 3 из 3
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  10. Motorola W490 Flex Cable Replacement: шаг 10, изображение 1 из 2 Motorola W490 Flex Cable Replacement: шаг 10, изображение 2 из 2
    • Pull the flex cable connection away from the top of the phone.
  11. Motorola W490 Flex Cable Replacement: шаг 11, изображение 1 из 2 Motorola W490 Flex Cable Replacement: шаг 11, изображение 2 из 2
    • Pull the camera connection away from the top of the phone.
  12. Motorola W490 Flex Cable Replacement: шаг 12, изображение 1 из 3 Motorola W490 Flex Cable Replacement: шаг 12, изображение 2 из 3 Motorola W490 Flex Cable Replacement: шаг 12, изображение 3 из 3
    • Pull the upper metal frame away from the phone.
  13. Motorola W490 Flex Cable Replacement, LCD Screen: шаг 13, изображение 1 из 3 Motorola W490 Flex Cable Replacement, LCD Screen: шаг 13, изображение 2 из 3 Motorola W490 Flex Cable Replacement, LCD Screen: шаг 13, изображение 3 из 3
    • Hold the outer phone casing and pull the LCD screen out.
  14. Motorola W490 Flex Cable Replacement, Flex Cable: шаг 14, изображение 1 из 2 Motorola W490 Flex Cable Replacement, Flex Cable: шаг 14, изображение 2 из 2
    • Remove the other end of the flex cable from the LCD board.
    • Pull the cable through the phone casing hinge and remove it.
Заключение
Will Edwards
Участник с: 10/22/12
61 Репутация
Автор 9 руководств
Команда
Clemson, Team 14-1, Benson Fall 2012 Участник Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 членов
Автор 23 руководств
2 Комментарии к руководству
How the !@#$ do you get the new flex cable in??? Id about anybody else, but mine was snapped in half when I opened it, thus, I was unable to see the original assembly... HELP???? Please??
Angela WM - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 60
За всё время: 1,287
