Запчасти
Никакие детали не требуются.
  1. Pick up the cell phone with the back facing towards you. Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery. Set the battery aside.
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles. Remove all the screws using the Torx T6 Screwdriver.
    • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
    • Remove all the screws using the Torx T6 Screwdriver.
  5. Turn over the phone to the front side and open up the phone, displaying the keypad. Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone. Pull and set the glued plastic cover aside.
    • Turn over the phone to the front side and open up the phone, displaying the keypad.
    • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
    • Pull and set the glued plastic cover aside.
    • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
  6. Under the plastic cover, locate two star-shaped T5 screws. Use the Torx T5 Screwdriver to remove the two screws.
    • Under the plastic cover, locate two star-shaped T5 screws.
    • Use the Torx T5 Screwdriver to remove the two screws.
  7. Turn over the phone to the back side of phone where the battery was removed. Use hands to remove the unscrewed rear frame of the phone. Set aside the rear metal frame.
    • Turn over the phone to the back side of phone where the battery was removed.
    • Use hands to remove the unscrewed rear frame of the phone.
    • Set aside the rear metal frame.
Заключение
Will Edwards
Участник с: 22.10.2012
61 Репутация
Автор 9 руководств
Команда
Clemson, Team 14-1, Benson Fall 2012 Member of Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 членов
Автор 23 руководств
Один комментарий
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 355
