Введение
Are your speakers not working? Having trouble hearing your favorite music? Here is a guide to replace the speakers. You will need to purchase new speakers before beginning.
Выберете то, что вам нужно
Pry off the back panel using a plastic opening tool.
Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
Using the tweezers, gently pull up the connector of each of the speakers.
Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers.
Еще один человек закончил это руководство.
